Budget: I have £450 for my build/upgrade Main uses of intended build: Gaming (FPS - BF 2/3/4, Sim - FSX/Train Simulator 2015/ETS2, Racing - NFS Hot Pursuit, Ridge Racer Unbounded, Others - MoH Splinter Cell Blacklist, Mass Effect) General internet use, Sketchup design, DVD ripping. Possibly doing the odd occasional rendering of video - My desktop is also used as a PLEX server for Music and Video Parts required: CPU, Mainboard, RAM, possibly GPU if budget allows otherwise will continue with current GPU until funds allow an upgrade. Previous build information (list details of parts): - i5 2400 (1155) - Asus P8Z68V-LX - 12 GB Ram (2x2GB 2x4GB) Corsair Vengeance - MSI R9 270X 2GB Gaming - ???? - Corsair Obsidian 750D Case - KEEPING FOR NEW BUILD - Corsair H80 Water Cooling AIO - KEEPING for now - will be going larger once funds allow - Corsair Force GS 128GB as OS Drive - KEEPING FOR NEW BUILD - 3TB Movies Drive - KEEPING FOR NEW BUILD - 1.5TB Gaming and Apps Drive - KEEPING FOR NEW BUILD - 1TB general Purpose - KEEPING FOR NEW BUILD Monitor resolution: 2x 1080P Monitors, 1x 24", 1x 22" Storage requirements: Will you be overclocking: yes/no (delete as required) Depends on my budget - Give me an idea for both if that's not being too cheeky Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): Need at least 7 SATA 3 ports and minimum of 8 USB at the rear Extra information about desired system: Going for a Blue and/or Yellow build as these are my favourite colours. I have no preference to AMD or intel CPU - whatever will offer the best bang for buck prefer using SCAN as i get free delivery, Amazon or Ebuyer for parts. Thank you in advance
Having a quick look on Scan you could get the following if you went with AMD. AMD FX8350 £134.20 MSI 970 Gaming £77.60 MSI R9 280 Gaming £149.99 Corsair H100i £90.12 Total £451.91 If you use your existing ram etc from your current pc, the other thing you could look at is getting a used I7 cpu from the marketplace once you reach the requirements, for it and then that would mean that you can spend abit more on the GPU and grab a GTX970 or AMD R9 290.
Why do you want a new CPU? Based on your needs it doesn't look like you need one. The main weak point of your rig is the graphics card. An r9 290(x?) would be a worthy upgrade. edit- I noticed you wanted a new mobo, one which wouldn't support the old CPU, ignore that first question
