Planning Need cad drawings done
Discussion in 'Modding' started by motas, 27 Jul 2010.
  1. capnPedro
    11 Apr 2007
  2. motas
    motas What's a Dremel?
    7 Dec 2009
    That was my plan but Im worried about it not fitting if it is slightly different. Thats why I wanted the lian li one.
  3. capnPedro
    11 Apr 2007
    The only problem I can imagine is if there isn't enough free space to the side of the PCI slot ends (i.e. you'd need a wide case)...
  4. motas
    7 Dec 2009
    Not a problem. I was thinking distance between back of tray and oci holding slots which does vary in cases.
  5. capnPedro
    11 Apr 2007
    Oh right, I see what you mean now.
    Do you have the dimensions already? Because most machine shots will program in the design if you give them a drawing of it. There will be an extra fee involved, however.
  6. motas
    7 Dec 2009
    No I cant measure it because my computers in there and i have no other case. I need to have my case finished to get the measurements to finish the case lol. Thats why I was hoping someone on here could memasure it up. Even a hand drawn sketch with measurements would be fine and I can just put it in autocad and send it off. Im also not confident enough to just measure a 3d object and turn it into a accurate net.
    Thanks.
