well im running a amd 2600 mobile on a nf7s mobo. im using a sp97(as5) with a tornado fan. my temp at idle seems to be 43c. load around 50c. im running at 11.5x217@2497. are these temps too high? also may want to try something different cause tornado is too loud. i tried a panaflow 92 mm fan but i idle a 51c. im using a super lan boy case with 3 120 mm fans.
that does seem a little high for sp97+tornado, but the nf7 sensors are pretty dodgy. What voltage are you running? How much thermalpaste did you put on? How hot is it inside your case?
