Development need easy pvr software
Discussion in 'Software' started by godspeed, 29 Jul 2004.
  1. godspeed
    godspeed Banned
    29 Jul 2004
    looking for a live cd based software
    pvr software on a live cd
    any ideas im shure its a good idea i did google only one result remotly close
    im shure its a small task for a linux guru im not quite there yet
  2. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    you can download a full live ISO for PVR's here . havent tried it yet because i dont have a computer with linux YET. Heard that this mythtv is really good especially if you are going to run it off of those mini-itx epia motherboards. but pretty much anything down to about 400MHZ will work pretty well
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Try Knoppmyth, it's a copy of the Knoppix LiveCD, with MythTV already compiled into it. I'm not sure if you can just run it
    on the CD, though. I think it has to be installed to your HDD.
    There is a warning, however. If you use the automatic installer on the CD, it
    completely wipes your primary HDD, and the manual installer doesn't work at all.
  4. godspeed
    godspeed Banned
    29 Jul 2004
    thanks pals
    oh well i think il just wait for somebody to come up with a good version of it
    it is a good idea im shure some ones working on a good version
