Build Advice Need expert opinion
Discussion in 'Hardware' started by GandalfDDUK, 30 Dec 2016.
  1. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Good time to upgrade from a i7 920 if you can afford it. You can get a good performance leap.
  2. GandalfDDUK
    GandalfDDUK New Member
    17 May 2009
    thanks that might be my next step if all else fails but have managed to get 920 overclocked and running at 3.92ghz with max of 4ghz at present.
  3. GandalfDDUK
    17 May 2009
    K running stable at 3.92ghz so think next step ssd then increase memory then new gpu and hey presto fairly decent rig again
  4. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Nice. Just keep in mind that you may want to back that off a bit for a long term OC, especially when summer comes around and ambient temps go up.
  5. GandalfDDUK
    17 May 2009
    right just found on amazon can get the exact same memory i have (6gb) for £55 making my system 12gb, would this along with my oc improve my system for now in minecraft and ark? with a view to getting an ssd for faster loading times as well, and further down the line a better gpu or would i still be p"£$ing in the wind?
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Sounds like a good plan to me as the SSD and GPU can always be used in a new system a few years down the road if, or when, the OC'ed CPU and extra RAM no longer cuts it.
  7. GandalfDDUK
    17 May 2009
    Thats what I was thinking but would doubling my ram now make any difference considering age of processor etc (6+ years) or would I be better going for new build considering the memory wouldn't be able to be used in a new system whereas most other things would as that could be £55 towards a new build. IF extra memory now would cut it I'll get ssd and gpu as oc as already improved system performance.
  8. play_boy_2000
    25 Mar 2004
    I'm beginning to sound like a broken record here.....
    YOUR PRIORITY SHOULD BE A SSD
    If you can afford both a SSD and the RAM, then by all means, spend away!
  9. mrbungle
    20 Sep 2004
    A SSD while great for all round snappyness if you have a issue with lag in a particular game it will do squat for that.
    Will load faster but won't help games performance one bit.
