Modding need help connecting laptop fan to molex
Discussion in 'Modding' started by Yaka, 6 May 2013.
    Yaka Modder
    26 Jun 2005
    well i got 2 blower fans pulled from a friends laptop which i am intending to use in a case. but am having trouble finding out which wire is which. the fans are Forcecon DC280009OF0 and pulled from a 14" alienware lappy
  2. Tealc
    Tealc What's a Dremel?
    6 Oct 2010
    Well it's a 5v DC fan so make a guess. If you wire it backwards it won't turn. Maybe if you are lucky the wiring will follow convention of 0v, 5v, tach, PWM.
    There's probably a really intelligent way to check using a meter but it's not something I know about.
    Yaka likes this.
  3. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Just to run the fan powered from a molex I'd say:
    Fan RED --> Molex Red
    Fan BLACK --> Molex Black
    Yaka likes this.
  4. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    its probably a 5v fan, how many wires a coming from it?
  5. Yaka
    Yaka Modder
    26 Jun 2005
    It is a 5v fan, was bored last night so removed the pins from the connector and had play with a 9v battery
    Red is positive
    White is pwm
    Yellow/gold is slow fan speed so prolly lover voltage
    Black is max speed and prolly the full 5v
    Sticker on the fans say 2cfm but at max speed it's spitting lodes air out, I do remember my Alienware m14x being more quiter than these 2 fans are
    Think I'll opt to Hook them up to pwm mobo fan connectors instead
  6. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Here is the Molex connector:
    Code:
    Pin	Name	Color	Description
    1	+12VDC	Yellow	+12 VDC
    2	COM	Black	Ground
    3	COM	Black	Ground
    4	+5VDC	Red	+5 VDC
    As for your fan black is ground not +5V. With four wires it sounds like it's a PWM fan so this is probably what it is:
    Code:
    1	+5VDC	Red	+5 VDC
    2	Control	White	PWM
    3	Sense	Yellow	Tachometer (RPM)
    4	COM	Black	Ground
    Yaka likes this.
  7. Yaka
    Yaka Modder
    26 Jun 2005
    Ah that make sense now mate thanks
  8. Yaka
    Yaka Modder
    26 Jun 2005
    thanks guys seems to be working fine and did wire em to to pwm cables instead of molex:p
  9. ferret141
    18 Oct 2010
    Thanks for the update.
