Ok, well I finally decided it was time for a hd format. So, everything went smooth and I got all my programs back on. Now a week has past and I just realized I never installed my wireless routers software. (Odd because the internet worked fine.) With the release of Counter-Strike:Source I began to play online after playing 50 bucks . After playing online for about 10 minutes I noticed that my lag was abnormally high, same for UT04. So I dug out my Linksys Wireless-B CD and did "Start -> Run -> D:/" then clicked "setup.exe". A grey box came up about the size of this forum's posting box that had the linksys install stuff on it. Then it just exits and I can't install the software. I also downloaded the drivers from www.linksys.com and the same thing happens. If anyone has any advice to increasing my internet connection speed please reply. I d/l off of www.download.com at about 100-200kb/s and on my computer downstairs (It's connected with a cable right out of the router) it downloads at about 700kb/s. Note: The icon in the bottom right says the connection is "Excellent 5/5 11Mbps"
