Need help finding Micro Atx mobos (nForce 2)
Discussion in 'Hardware' started by Dredog, 14 May 2003.
  1. Dredog
    Dredog What's a Dremel?
    8 Dec 2002
    Are there any other nforce 2 Micro-Atx motherboards other than the Chaintech Summit and Shuttle ?
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    MSI M7VNIC or something like that.
    My friend has its, its a very good board. Its on a red PCB
  3. Dredog
    8 Dec 2002
    are you sure it's a micro atx motherboard? i can't find anything on their site
  4. herbs
    herbs Nobody but us chickens
    7 May 2001
    I believe gigabyte do one I did see a review the other day but I can't remember where I saw it.
  5. Morphine
    Morphine weeee!
    23 Feb 2002
  6. olv
    olv he's so bright
    23 Sep 2002
    is there any significant different in performance between normal atx and matx motherboards based around the same chipsets? thinking of getting a matx for a project but dont want performance to suffer.
  7. Dredog
    8 Dec 2002
    There isn't any real diff. in performance. The only thing is that you don't have as many overclocking options. Check out this review at Hexus.net
  8. olv
    olv he's so bright
    23 Sep 2002
    I cant find any decent suppliers of nforce2 matx boards in the uk. have u had any luck dredog?
  9. olv
    olv he's so bright
    23 Sep 2002
    ahhh i see your in the US :( anyone know of any UK suppliers of matx nforce2 boardS?
  10. olv
    olv he's so bright
    23 Sep 2002
    Dredog there is this aopen one which seems very nice. i think i'll be getting it.
