Electronics Need help identifying a surface mount capacitor
Discussion in 'Modding' started by bixie_62, 11 Sep 2005.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey
    i've got my brothers laptop,and one of the surface mount capacitors has blown, its cracked.
    its brown in colour and i was hoping that they had diff colours for diff values.
    is there anyway to identify which capacitor it is?
    thanx.
  2. ARM
    ARM Minimodder
    15 Sep 2004
    Hi Bixie,
    As far as I know, there's no way to know the value. SMT chip capacitors colours has got no relation with the value. SMT tantulum and electrolytic capacitors have their value (and voltage rating) written on them.
    As a long shot, if you are willing to take the risk, measure another chip capacitor which is the same colour and size; that might be the value of the burned cap. (you may have to unsolder the chip cap. before measuring, since it might be connected to other components).
    Hope this helps.
    ARM
  3. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    No text or numerbers on it then?
  4. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    Small smd caps shouldn't damage stuff if they are the wrong type, they wont work. Don't quote me on this though...
    EDIT: Just make sure you switch off quick if you see smoke...
  5. Starman97
    Starman97 What's a Dremel?
    17 Sep 2003
    About the only way to tell, would be to pull a few other caps
    that match it in size and color and measure thier values.
    Then use the highest voltage available for that package size
    and measured capacitance.
    It may be an part who's absence wont affect operation, or it
    could be part of a power supply or video circuit and be vital.
    The only thing I can suggest is to clean off the remains so it
    doesnt cause a short circuit as bits of it fall off or the internal
    crushed layers short out.
    If it's tiny and there of lots of others just like it, it's probably a
    decoupling cap and it's loss is no big deal, but if it's bigger than
    most of the others or a unique color, it's likely to be important.
    Check for other damage as well, cut traces, bent pins etc.
