hi.....i need help findin infos in the internet about case size mother board size...where the screw holes should be (like a blueprint) ...i want to build custom case..with 2 motherboards and want to plan it good before startin buildin it (once i did it otherwise ..maybe one day im not too ashamed to post pics from my first mod here) .....sooo feel free to post links about custom case building (dont get me wrong ...i need infos like technical plans or so ...not to difficult (dont get me wrong here agagin)) .....or suggestions ....ok my plan is to build a custom case with a double proz board and a single proz in one case...hope u understnad my plans cause my english suxxs sometimes when im under controll of stimulatin substances (dont get me wrong here..nothin to worry) ...ok thanxc for readin this ..and applause for postin somethin usefull........ by the way .....best site i found till now for case and moddin stuff...give u 10 out of 10 stars
I am assuming you are planning on using standard ATX mother boards since that is the norm currently. This should help.. check out section 3 "Layout" or you could lay your board down on the material and trace the mounting hole locations..
Welcome to the forums mate. www.motherboards.org has a lot of info about motherboards. Could be a good place to start.
If you want to know where the ATX standard specifies that motherboard mounting holes should be, you need to look up a white paper or technical specification on the ATX standard. I should think that intel would have such a thing on their website, and many other also. Do a google for it.
