Build Advice Need help on my first build
Discussion in 'Hardware' started by gmailbond, 14 May 2011.
  1. gmailbond
    gmailbond What's a Dremel?
    14 May 2011
    Hi To every1 out ter,
    Need some suggestion on my first gaming build.
    want to know like will all these work together and accommodate in the Cabinet,is PSU sufficient or any good PSU advise any Mob advice
    Intel i5 2500k
    ASRock Extreme4/6
    MSI N560GTX-Ti-Twin-Frozr-II-OC
    CPU Cooler Thermaltake Frio
    Thermaltake V9 Black Edition
    Corsair PSU TX750
    Corsair vengenance 4gb (1.5v)
    Samaung 1TB HDD,
    Blu ray Drive
  2. longweight
    7 May 2011
    750W should be plenty for your system!
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    have a look at the asus p8p67, its meant to be one of the best boards for sandy bridge chips, just as long as nothing has changed since the b3 revision, also that psu although very good for its time is a bit old in the teeth now, try one of these http://www.scan.co.uk/products/650w...e-85-eff-sli-crossfire-eps-12v-135mm-gray-fan
    or this if you'd rather stick with corsair http://www.scan.co.uk/products/650w...bronze-85-eff-sli-crossfire-eps-12v-120mm-fan
    also some people I believe have problems on there motherboard with the vengeance memory, so take a look at this, same sticks but with different "heat spreaders" http://www.scan.co.uk/products/4gb-...00-(1600)-non-ecc-unbuffered-cas-9-9-9-24-15v
    if you like the look of that thermaltake case, have a look at the haf 932, antec 902/ 1200 or if you prefer something more subtle have a look at the fractal design r3
  5. gmailbond
    14 May 2011
    Thank u guys for all ur advise
    @thetrashcanman
    1.PSU -wanted to like the HX650 would be sufficient for SLI config with the MSI 560ti and how is Antec TP750 or any good seasonic psu or Silverstone
    2.Wanted to know like how is Gskill ripjaws memory Model F3-12800CL9D-8GBRL
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
    and like wat r the vengence series of mems issues with sandybridge chips
    And comin to Cabinet i do have looked at the haf and others but right now have a budget henceforth going for the Thermaltake V9 price range or near by ones.
    And lastly would these all fit together in the thermaltake cabinet and would all these hookup and work
  6. gmailbond
    14 May 2011
    @thetrashcanman
    or
