Hi all, Just got this projector for my office, the image/sound are good but there are these vertical line (kind of thick vertical line or thin vertical colour bar? ) spread evenly across the screen, these line bar changes colour with image, but stable and always there. At no signal input, it should be total white or black blank screen, it shows the same stable black and orange vertical lines all across, fully covered the whole screen. Can anybody tell me whats wrong with it? Had downloaded and installed the PSA software, cant find any service function correspond to this problem. Thankyou. Pang
thanks for the reply, I got it in ebay singapore and seller stated no return of goods, the reason I bidded is because the lamp hour shows only 28hr in the projector... so it may be being replaced with an old bulb
Worth a go to see if it is the bulb, my friend had a similar issure when he set up xbox 360 with a projector he brought off of ebay, thankfully he managed to get a new bulb from a local barlows electrical shop.
