Graphics Need help please
Discussion in 'Hardware' started by peteone, 11 Apr 2003.
  1. peteone
    peteone What's a Dremel?
    5 Jun 2002
    Hi folks, I just got my gainward TI4200. Im running win 2k and trying to stretch the desktop between 2 monitors (one from the VGA out and the other from DVI-VGA converter). The problem is it deesnt see the second monitor.
    It clones the second monitor from startup but it is not listed in any of the NVIEW or Ultramon settings.
    Should the device manager in windows show 2 monitors? Because it doesn't.
    Also some of my icons in my taskbar have gone all hairy, not sure if this has anything to do with it.
    I have updated the drivers but still nothing.
    Does anyone have any suggestions?
    Thanks!
    Pete.:sigh:
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    I had a similar problem it was down to the drivers at the time that buggered up nview, so try another driver. Hope that works.
  3. banished
    banished Necromodder
    6 May 2002
    uninstall the drivers, then you will need to re-install while both monitors are on. That's the important part.
  4. peteone
    5 Jun 2002
    Cheers!
    Herbs, I have tried a few drivers and none seem to sort out my problem.
    Banished, im a bit confused can you explain what you mean by
    Do you mean uninstall both monitor drivers or graphics card?
    Can you elaborate please im realy stuck.
    Thanks for your help!
    Pete.::lol:
  5. banished
    6 May 2002
    drivers
  6. peteone
    5 Jun 2002
    Cheers allready tried that a few times, didnt work though.
    I dont think my comp is recognising both monitors, no mater what I try I can only get it see one monitor in the device manager.
    Anyother ideas?
    Thanks!
    Pete.
