Need help settin up SATA ASAP!!
Discussion in 'Hardware' started by Carlk, 15 Jul 2004.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    hey, just got my SATA hard drive,when i go 2 install XP i press F6 and it askes me to install the hard drive, it asked for the SATA floppy disk?!?!? anyone know what im talking about? Ive no idea where to get this flopy disk!
    I realy need some help
    thanks
  2. Jedi
    Jedi What's a Dremel?
    16 May 2004
    it's refering to a floppy disk that should have come with your motherboard or controller card.
    if u didn't get one then head to the mobo website and see if u can download the files
  3. Carlk
    10 May 2004
    You Beast you!! thanks, didnt know it was that simple! :D
    :thumb:
  4. Carlk
    10 May 2004
    ahhhh.... had a look on asus website and I cant find it anyware :sigh:, i have a Asus A7N8X-E Deluxe motherboard. any ideas?
  5. Will
    Will Beware the judderman...
    16 Jun 2001
  6. Carlk
    10 May 2004
    i downloaded them. what i do now? still says its not the right file 2 continue with the XP setup :sigh:
  7. phuzz
    phuzz This is a title
    28 May 2004
    Not sure if you've already done this, but you'll have to put the drivers on a floppy, probably in a certain set of directories (something like drivers\Si3112\winxp, but that's just a guess based on what I've seen), if there's any readme's with the drivers they might hopefully be able to give you a bit more info...
  8. Carlk
    10 May 2004
    :thumb: thanks alot peaps! all done and sorted :rock:
    nice and quick :naughty:
    tanks!!
