Need help with ati sapphire x800 gto pci-e
Discussion in 'Hardware' started by Dawny, 30 Dec 2005.
  1. Dawny
    Dawny What's a Dremel?
    1 Dec 2005
    got all my parts today, after putting everything together, installed windows xp. then after i installed the driver for my sapphire x800 gto, the system wouldnt boot and it kept asking to boot from cd-rom. i'm just wondering what i'm doing wrong, i think the psu isnt enough. any thoughts?
    Motherboard: msi k8n neo4
    CPU: AMD (Venice) Athlon 64Bit 3200+ Socket 939pin 512k L2cache 90nm
    RAM: Kingston 1GB 400MHz DDR PC3200 DIMM 3-3-3
    Video Card: Sapphire X800GTO 256mb GDDR3 PCI-E
    PSU: Hiper 425W Low Noise Dual Fan
    Hard drives: Western Digital WD2500JD 250GB 7200RPM SATA/150 8MB Cache
  2. Sgoaty
    Sgoaty Minimodder
    4 Feb 2005
    The PSU will be fine. Is the XP CD still in your drive?
  3. Dawny
    1 Dec 2005
    no it was after i installed the gfx card, and it was trying 2 boot from the gfx card cd so i took it out, and it start asking 4 system disk. welll it worked before hand with installing xp on 640x480 pixel, dunno if that helps
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    Sounds like the drivers have become somehow corrupted; it's also possible that you have a defective card. Does the BIOS or Windows keep asking to boot from CD? Check the boot order in your BIOS to make sure it's set to HDD first.
  5. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Well i have problem where everytime i restart it asks for system disk. All i do is insert disk and press enter then it boots. A hasel yes but alot easier then reformating. My problem was a screwed up partitioning made a partition before my windows partition.
    Is that the first time you rebooted the system after instal.
  6. Dawny
    1 Dec 2005
    guys thnx 4 the posts, sorted out my problem, cuz when i installed xp had my old harddrive on it, with cable select and my old drive turns out 2 be the master. all the master boot record was saved onto that, and that's y it wouldnt boot. so problem solved. thnx again ^^
