A/V need help with car speakers
Discussion in 'Hardware' started by Irteza, 6 May 2004.
  1. Irteza
    Irteza Banned
    14 Mar 2004
    i bought some car speakers for my honda but my car stereo is too powerful and the bass distortes is the a way i can keep the treble high but put the bass down if i do that through the cd changer the bass for the sub goes down aswell
  2. penski
    penski BodMod
    29 Aug 2002
    What speakers, what head unit et cetera, et cetera?
    *n
  3. Irteza
    Irteza Banned
    14 Mar 2004
    its a sony headunit
    and some cheap rieson speakers from maplin but good sound quality though
    is there a way i can adjust the bass without affectuing the treble
  4. micb
    micb Minimodder
    4 Sep 2002
    It is likely the speaker distort because you head unit is not powerfull enough, headunits amplfier power output is actually quite low.
    If you don't want to turn the bass level down on the headunit because that reduces bass to you subwoofer then what you do is install a custom passive crossover filter (a set of exact capacitors) to stop bass going to you speakers.
    I can exactly tell you what components you need to do this.
    What is you whole system and how is it wired?
    I need to know what impedance your speakers are 4 or 8 ohm?
    Also the crossover point of your subwoofer would be usefull?
  5. Irteza
    Irteza Banned
    14 Mar 2004
    its some sony headunit
    magnat amp 4 channel
    kenwood 12" sub
    speakers are 4 ohm in the front door
    can you tell me abt the capacitor thing which one shuold i buy
