Build Advice Need help with computer parts upgrade
Discussion in 'Hardware' started by Rikaderic, 26 Mar 2010.
  1. Rikaderic
    Rikaderic What's a Dremel?
    26 Mar 2010
    Begginer at trying to put my computer togather. My computer and my motherboard went bad so decided good time to just upgrade it. bought these...
    GIGABYTE GA-MA785GM-US2H Motherboard
    XFX HD-577A-ZNDC Radeon HD 5770 XXX Edition 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
    AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX
    OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK
    Western Digital Caviar Blue WD2500AAKS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    .. Well bouth it and had it shipped and got here today. Then i noticed my ext. memory did not fit and not starting to question how many other things i did wrong and need to return. Motherboard said compatible with windows 7 but i have xp? IDK totaly lost just looking for some help here on what i should return and or stuff i need to buy with it. Thank Rikaderic
  2. Seeks
    Seeks Minimodder
    13 Feb 2010
    motherboard will work with XP. The issue is you got DDR3 RAM for a DDR2 board... so you need to get DDR2 RAM. Rest should work
  3. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    The ram is also for a intel 1366 system. you need dual channel, not tri. You're probably better off returning the ram as even if you want a DDR3 system its a bit overkill. The rest is all good.
    If you want DDR3 system you will have to change the mobo.
    Where did you get your stuff from btw?
  4. Baz
    Baz I work for Corsair
    13 Jan 2005
    It's always frustrating with these newbie posts - stuff we take for granted is really pretty far out there for the average users.
    @Rikaderic - If you're not a bot, there's quite a lot to consider. First up, as other have said, you've bought the wrong ram and need some DDR2. An 800MHz 4GB kit should do fine.
    You'll also need a power supply with a six pin PCI-E connector to power your new graphics card. If your original system was an OEM model (like a Dell), its PSU might not have one, or might not have sufficient wattage to power your new build.
    Finally, all your new hardware will work in Windows XP, but you really should consider the jump to Windows 7. After all, XP is an 8year old OS and 7 offers a BIG upgrade in all sorts of respects. A retail version of home premium is only £90 and is well worth it.
  5. Rikaderic
    26 Mar 2010
    Sorry about the delay for replying but on a break down computer which has problems of its own. Thanks for the help Seeks. Domestic_ginger I got the stuff from newegg.com. For Baz yes i am a noob in many senses i use to mess with computers alot but that was way back at pent. 2 about. My friends and i built my last computer about 3 years ago and dont mind doing the installing and all, but i never bought the parts they told me what i needed. My power supply is a 550watt i have it the 6 pin pci-e that comes off the power supply. The whole windows thing i am use to old school windows. I just need to break down and learn a new windows:)... Maybe some year i will. Thanks for your help and been browseing your site and like how active your site is.
  6. Seeks
    Seeks Minimodder
    13 Feb 2010
    I really would reccomend windows 7 over xp. not just because its the latest version but also because, at least in my opinion its just better. Can do so much more and its definetly worth the 5-10 mins it takes to learn it. You really can just jump in, if you have half a braincell it really isnt much of a learning curve at all. Especially if you know XP. Yes some things are in different places and there are some weird things but you wont regret changing. If you are getting a new PC why not get a new OS?
  7. Rikaderic
    26 Mar 2010
    OCZ Gold 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2G8004GK - Retail
    DDR2 800 (PC2 6400) Timing 5-5-5-18 Cas Latency 5 Cas Latency: 5
    Voltage: 1.8V
    Multi-channel Kit: Dual Channel Kit
    Recommend Use: High Performance or Gaming Memory
    Model #: OCZ2G8004GK
    Item #: N82E16820227199
    K that has everything i think you were talking about. Besides newegg.com do you recommend other besides tigerdirect.com dont like that one. Hope thats right going to get those. Going to go to Best buy and buy windows 7.
    thxs
  8. rollo
    rollo Modder
    16 May 2008
    that ram is fine that you listed
    windows 7 you should def buy
  9. Rikaderic
    26 Mar 2010
    Well I have Windows 7 up and running in the new computer. Just need to check to see what items i wanted to save from my old hard drive. Other then that everything on track with programming part of it. Thanks all for the info.
