Electronics Need help with fan mod...
Discussion in 'Modding' started by mpatel616, 20 Feb 2002.
  1. mpatel616
    mpatel616 What's a Dremel?
    12 Feb 2002
    Hey guys, I've been trying to mod one of my fans to do the spinning LED mod to it but everytime i try to get the circle magnet out of the inside of the fan blade housing it just doesnt budge. I have tried 3 different fans, one 60mm off a coolermaster HSF, a 80mm ADDA from my Lian-li pc60 and a Panaflo L1A 80mm. I have drilled a small hole in the tops of each housing to push the magnets out but they still wont budge.
    does anyone know how to get the damn magnet out?
  2. mpatel616
    12 Feb 2002
    Anyone know about the circular magnets?
  3. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
    well, if there well glued in there, you might be out of luck......perhaps try some glue disolver......you should be able to find it at an hobby shop
  4. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    They are not easy to get out. Mine wasn't glued, but you need to drill a hole directly above it and push it out with a small screwdriver.
    Be careful though! I was playing around with a $1 fan and I broke off the fins on the fan while getting that ring out.. lol
  5. ChriX
    ChriX ^
    30 Aug 2001
    lol! thats what you get for buying a $1 fan! :)
  6. KevinOwns
    13 Jan 2002
    Yup.. lol. I really only bought it to destroy it, the fan was such a piece of crap it would not be of much use cooling a system.
    It was still fun to do though :cool:
