Modding Need help with finding what I need
Discussion in 'Modding' started by chrisc1277, 1 May 2010.
  1. chrisc1277
    chrisc1277 Minimodder
    12 May 2009
    hi, thanks for looking.
    i need help, im looking to add a second 200mm fan on the side of my coolermaster Cosmos S. to do this though i need to replace the plastic bracket/filter where the current fan is installed on the side panel (if you got one you might know what i mean) and replace it with a new filter in which i will attached the fans in the positions i want.
    the question is, does anyone know where i can find a sheet of dust filter atleast 49cm x 34cm big? i thought b & Q but i cant see it on their website and ive tried typing it into google with little success.
    anyway thanks for looking and any help will be greatly appreciated.
    chris
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Get a big pair of ladies tights and stretch across the fan. Perfect filter.
  3. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    ^ Tights work as decent dust filters
    or
    Ebay - search for 'insect screen mesh'
