Need help with internet connection + steam
Discussion in 'Tech Support' started by OldY, 18 May 2006.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Firstly -
    I have a wanadoo adsl which connects to the computer via usb. When I connect to my gaming pc, I get a strong connection for about 2 minutes then the connection stops altogether. Then I connect to my laptop and it works fine?
    To try and fix this I have uninstalled and installed about 4 times no with no avail.
    Secondly -
    When I press "launch" on half life 2 - the preparing to launch window comes up, but where is says 100% ready changes to downloading paused but I have downloaded all the updates - then the preparing to launch window goes off and nothing changes.
    Please help as I have given up the will to live and the computer has almost gone out the window :D
  2. Hopakee
    Hopakee What's a Dremel?
    21 Apr 2006
    Do you have the drivers installed? Since it works on your laptop It has to be you computer. Have you tried and jack it in another USB port ?
    as for the HL2 part. Try and reinstall the latest patch/download. sounds lame but google and type your exact problem:halvelife2 launcher keeps downloading and then stops.(or anything like it)
    You will find alot of forums containing those fanatic gamers that have the same problems.
    Hope it helps.
    GreetZ
    Nick
