Windows need help with my dad's POS machine and internet
Discussion in 'Software' started by Da_BaCoN, 23 Dec 2003.
  1. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    my dad's pc is being a pain lately. he's going to let me build him a new one after the new year's, but until then, he needs to get his pc fixed/running. right now he's using AOL (i know, i know) for his internet, and it's acting really weird. it will connect to the service and he can check/send email, but he can't go to any websites. this happened out of nowhere, and i can't figure out what's causing it. any ideas?
  2. Shogun
    Shogun Banned
    18 Jul 2002
    dns servers down maybe?
  3. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    hrmm... not sure. i'm not there atm, so i can't check. actually, what would i need to do to check it anyways?
  4. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    An act of God.
    Seriously though, the easiest way to test it is to copy the IP of a remote location, such as your machine's IP, then open up the CMD, and go:
    ping <YourIP>
    If that works, you've got a solid connection.
    Now go:
    ping www.google.com
    Or a similar DNS address, if it goes fine, then DNS is fine and your problem lies within your browser most likely. However if that ping doesn't work then either AOL's DNS is knackered, or your settings are wrong. Go into your network settings and check everything out according to teh DNS information AOL should have provided you with.
    Good luck.
  5. tk421
    tk421 Idiot.
    15 Jan 2002
    also:
    try "ipconfig /flushdns" from the cmd prompt.
