Displays Need help with my monitor
Discussion in 'Tech Support' started by gshtong, 10 May 2009.
  1. gshtong
    gshtong What's a Dremel?
    2 May 2009
    I have a XFX HD4870X2 graphics card connect to a Samsung T240 through DVI cable
    every time I turn on the PC, it is not always that the monitor will pick up the signal, I have installed the driver, and that doesn't immprove either. Do anyone what's the problem and how to solve it?
    thank you
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    you try both dvi ports on the back of the card.. and this is probably a dumb question but does your mb have on-board vga? if it does you can turn that off in the bios
  3. bullseye
    bullseye Who dares wins
    28 Apr 2009
    Have you installed the monitor drivers you may have to do it manually and select the dvi drivers.
    If you dont have the CD, they can be found here. http://tinyurl.com/or8nc2
