i need some help with a modding a mod. macorman made this knight rider mod : http://www.bit-tech.net/article/82/ and i was wondering if it was possible to add a on/off switch to the lights so you could turn off the display when you wanted too. P.S. i have started to make one of the coolest cases ever seen in life. it is in the drawing stage right now dont keep hopes up hhigh yet. thx for the help
What you can do is put two connection points between +12v and R8, wiring the switch up there, or (probably neater) use a switch inline between either +12v or Ground on what ever power connector you're using.
