need help
Discussion in 'Hardware' started by Luda, 19 Jul 2003.
  1. Luda
    Luda What's a Dremel?
    8 Dec 2002
    well i got my new system all up and running. and its great!.. when its working that is.. it seems i dont yet have my sytem stable yet. sometimes ill be playing counter-strike, or watchin tv on my GFX card, and the program will just shut down, or my whole computer will turn off.. im new to this stuff so the only thing i could think was over heating? btw.. i dont have it overclocked at all yet... any help would be very appreciated
  2. Prae
    Prae What's a Dremel?
    16 Jul 2003
    what cpu u got in the system, if ur comp shuts down due to overheating it will beep a few times and shut down, you can check in ur ios what temp ur cpu will have before its shuts downin order to protect the thing from frying. what sorta temps u got on boot up? and running. tho the shutting down of programs now and again and not the whole system dosent sound liek over heating..anyhow if ya get back migth be able to give ya a hand
  3. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Luda, In your other thread you had PSU problems. I know you fixed them but what psu did you get. It could be that your GFX card is trying to draw too much when youre playing games.
  4. Luda
    8 Dec 2002
    i got an antec 400 watt.. the problem at first was my first psu dint have the four pin 12V connector... what im thinking now is that drivers are interfering withn each other.. so im reformat/reinstalling and installing my custom gfx card and sound card drivers only use the drivers my mobo gave me when necessary
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    i remember my tv tuner doing that years ago with teh same symtoms and stuff. my solution was installing xp. i then realised that voodoo went out of business and couldnt get drivers. oh well what could i have done anyway. oh yea voodoo files.com didnt have what i need. anyway your problem is somehow your drivers. try out the latest drivers and if they dont work well uninstall them and go to a earlyer driver. im running a little bit outdated drivers on my system becuase the newest ones caused my screen to get messed up after a minute. your rebooting is windows shutting down after a BSoD.
  6. Luda
    8 Dec 2002
    i was just running SiSoftware Sandra and it told me my mainboard was 127 degrees celcius! im guessing this is why my pc keeps crashing ... but i dont understand because my case has 4 fans.. i guess they arent placed very well? any tips are appreciated
  7. Luda
    8 Dec 2002
    heres what the "Performance Tune-Up" report said:
    SiSoftware Sandra
    System Summary
    Analysing...
    Finished Successfully : Yes
    Mainboard Information
    Analysing...
    Power / Aux Temperature : 127.0°C / 260.6°F
    Notice 224 : SMBIOS/DMI information may be inaccurate.
    Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
    Warning 2518 : Mainboard temperature is too high.
    Tip 2513 : AGP Bus is unused or AGP card not fully AGP compatible.
    Tip 2525 : Current AGP data rate not optimal.
    Tip 2536 : System has no SMBus/i2c/BMB bus support.
    CPU & BIOS Information
    Analysing...
    Notice 224 : System BIOS : SMBIOS/DMI information may be inaccurate.
    Tip 207 : System BIOS : A SMBIOS/DMI 2.3 or later compliant BIOS is recommended. Check for a BIOS update.
    Tip 212 : System BIOS : BIOS can be shadowed so check whether it is.
    Tip 211 : System BIOS : BIOS is flash-able and socketed so it can be upgraded when needed.
    Tip 210 : Processor 1 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
    Notice 224 : Processor 1 : SMBIOS/DMI information may be inaccurate.
    APM & ACPI Information
    Analysing...
    PCI, AGP, CardBus Bus(es) Information
    Analysing...
    Warning 1209 : ATI Technologies Radeon 9700 Series - Secondary : Video card does not have an interrupt assigned.
    Tip 1202 : Chaintech Computer Co Ltd Unknown (1724) : Device does not support bus mastering.
    Video System Information
    Analysing...
    Tip 319 : ALL-IN-WONDER 9700 SERIES : A refresh rate of at least 75Hz is recommended. Increase it if possible.
    Tip 322 : ALL-IN-WONDER 9700 SERIES : Turn off screen savers. Use the monitor power saving mode.
    Tip 323 : ALL-IN-WONDER 9700 SERIES : Remove the desktop wallpaper to save memory and improve performance.
    Tip 319 : ALL-IN-WONDER 9700 SERIES - Secondary : A refresh rate of at least 75Hz is recommended. Increase it if possible.
    Tip 322 : ALL-IN-WONDER 9700 SERIES - Secondary : Turn off screen savers. Use the monitor power saving mode.
    Tip 323 : ALL-IN-WONDER 9700 SERIES - Secondary : Remove the desktop wallpaper to save memory and improve performance.
    Windows Memory Information
    Analysing...
    Drives Information
    Analysing...
    Warning : 1.44MB 3.5" (A:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Warning : Removable Disk (D:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Warning : Removable Disk (E:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Warning : Removable Disk (F:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Warning : Removable Disk (G:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Warning : CD-ROM/DVD (I:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
    Ports Information
    Analysing...
    Keyboard Information
    Analysing...
    Mouse Information
    Analysing...
    Sound Card Information
    Analysing...
    Printer and Fax Information
    Analysing...
    Error : No printers installed : Could not initialise the Print object!
    MCI Devices Information
    Analysing...
    Windows Information
    Analysing...
    WinSock Information
    Analysing...
    Processes Information
    Analysing...
    Tip 1601 : [System Process] : Program consumes a large amount of memory.
    Tip 1601 : SiSoftware Sandra : Program consumes a large amount of memory.
    Modules Information
    Analysing...
    OLE Information
    Analysing...
    DirectX Information
    Analysing...
    Error : IPX Connection For DirectPlay Ver 6.00 : Function Unavailable
    Network Information
    Analysing...
    SCSI Information
    Analysing...
    Warning 2600 : WDC WD80 0JB-00ETA0 : SCSI version does not adhere to ANSI. Probably ATA/ATAPI device.
    Warning : No devices on host : No devices found.
    Warning 2600 : SONY DVD-ROM DDU1621 : SCSI version does not adhere to ANSI. Probably ATA/ATAPI device.
    Warning 2600 : SONY CD-RW CRX220E1 : SCSI version does not adhere to ANSI. Probably ATA/ATAPI device.
    Font Information
    Analysing...
    CMOS Information
    Analysing...
    OpenGL Video Information
    Analysing...
    Services Information
    Analysing...
    Tip 2130 : Messenger : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Remote Access Auto Connection Manager : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Remote Registry : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Task Scheduler : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Secondary Logon : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Distributed Link Tracking Client : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Windows Time : Service may be disabled on Home/Professional OS version.
    Tip 2130 : Windows Management Instrumentation : Service may be disabled on Home/Professional OS version.
    ATA/ATAPI Information
    Analysing...
    Data Sources Information
    Analysing...
    Error : Connect to DSN failed/inactive : Could not connect to the database.
    Hardware IRQ Settings
    Analysing...
    DMA Settings
    Analysing...
    I/O Settings
    Analysing...
    Memory Resources
    Analysing...
    Plug & Play Enumerator
    Analysing...
    Performance Tune-up Wizard
  8. Froggy
    10 Jun 2003
    ok i didnt read the full thing but i am going to assume that it was a inacurate reading. 127 C is above boiling point. i dont know what temp causes a mobo to fry but i dont think your computer would be working still if that was its temp.
  9. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    Man, if you have 127 c on your motherboard you should try to feel it with your hand.
    If you can't feel that heat probabaly is a temp misreading from the bios (and you can set "ignore" to bios monitoring).
    If you feel the heat pal, you have a very serious problem with your mobo :(
  10. Froggy
    10 Jun 2003
    sisoft sandra is inaccurate. i just ran it on my computer and it thinks my processor voltage is se to high. im like umm no i undervolted from 1.525 to 1.375 and it runs stable.
  11. Luda
    8 Dec 2002
    well my pc is still proving to be unstable, which is upseting when i just spent 2000$ on it..
    more details on symptoms:
    -i'll be using a program such as AIM or IExplorer and it will give me the send/dont send report close dialog and when i try to reopen it it gives me the same thing untill i restart
    -ill be playin counter-strike and my pc will just restart out of nowhere
    at this point all i can think is unstable drivers or bad RAM
    are there any good diagnostic tools for software/hardware besides sisoft sandra? or anyone know of any common issues?
    here are some details from my mobo OC utility
    CPU - fan 3444 RPM - 46C
    SYSTEM - fan 0RPM??-34C
    Vcore - 1.5V
    Vdimm - 2.64V
    Vddq agp- 1.52V
    Memory - 400
    200 MHz FSB
    PCI&AGP - 66&33
    CPU speed - 2800
    CPU multiplier - 14 ???
    thanx for all yalls help.. im really hoping to get this stable soon because you want/expect good quality from 2000$.. specially since all the products got good reviews.. oh well.. any suggestions appreciated
  12. Luda
    8 Dec 2002
    please.. anyone?? - bump, bump bump it up
  13. sja360
    sja360 What's a Dremel?
    3 Jul 2003
    try using memtest to check ur memory,
    as for your temps they should be fine (i think)
    try gettin a shot of some memory from someone and then remove ur stuff and see if its stable.
  14. Froggy
    10 Jun 2003
  15. Luda
    8 Dec 2002
    ok.. i ran memtest twice.. each time for about 5 mins 45 seconds and the first time it found 1588 errors and the second it found 2104 errors.. this seems like a high number? could this be my problem? i have no idea how signifanct each error is.. thanx again
    hmm /looks at memory package.. sees "award of Excellence - Bit-Tech"
  16. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    really it sounds VERY likley to be your RAM or CPU. memtest is a pretty good app ate detecting problems. Don't knock the award for excellence. it's always great unless you have a faulty one :D
  17. Luda
    8 Dec 2002
    ok.. ima see about RMAing it ASAP
  18. Froggy
    10 Jun 2003
    your error count should = 0
  19. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    woa woa, i just did a thread saying my temp was exactly 127 degrees.... cant be a coincidence surely
