Modding Need internal USB 3.0 ribbon/right angle connector
Discussion in 'Modding' started by SuperHans123, 9 Feb 2021.
  1. SuperHans123
    SuperHans123 Minimodder
    27 Dec 2013
    As we all know, the USB 3 internal cable is massive and blocks access to some internal parts of builds.
    Is there a decent right angle or sleeved low profile extension someone can point me in the direction of?
    (Mods, please move if posted in wrong forum)
  2. David
    7 Apr 2009
    Do you mean this?
  3. SuperHans123
    27 Dec 2013
    I sort of did mean this, or a cable with this at the end perhaps.
    This one has some very poor reviews, so was a bit wary.
    Surprised they aren't more commonplace given the size of the stock USB 3 cable.
  4. Cheapskate
    13 May 2007
  5. SuperHans123
    27 Dec 2013
    Thank you.
    Yes I saw this site but thought there may be a UK based one to buy from.
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    I bought these recently to tear apart and test
    https://www.ebay.co.uk/itm/2-Pack-S...ion-Header-Adapter-Cable-forH2U3/174548938557
    I didn't have much luck actually making my own USB 3 connector using Molex Milli-grid connectors and USB 3 DIP PCBs, but I tested these extension cables and they're fine. No markings on the wire either, so no need to sleeve. They're not very long though, so depending on your case you might not have enough length to tuck the connection away.
  7. slimithy
    slimithy What's a Dremel?
    20 Aug 2014
