Graphics Need more (cowbell) monitors
Discussion in 'Hardware' started by FuzzyOne, 10 Jun 2012.
  1. FuzzyOne
    FuzzyOne
    19 Sep 2002
    So I've been out of the loop for so long now I have no idea what I'm doing.
    Here's what I want, I have a 5770 powering two screens, I would like to add a third.
    If I want to run just three screens can I do this with the 1 5770.
    My 5770 has 2x DVI [In Use], 1x HDMI and 1x (I assume) Display Port.
    With that out of the way, if, in future I wanted to a fourth I'm assuming I'll need to chuck another 5770 into my system.
    Thanks :thumb:
  2. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    With the 5770, two monitors at once is the max. You'd have to get another card to go along side it to connect more.
    Edit: I'm sure the thread title changed as I was replying... :eyebrow:
    FuzzyOne likes this.
  3. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Thanks Fantus, So if I just chuck another 5770 in i'll be fine, I assume I can crossfire them too?
    BTW where in Ipswich do you live?
    docodine likes this.
  4. Fantus
    25 Jun 2010
    If your board supports crossfire and you've got the power connections from the psu, chuck it in and install the latest driver.
    I live in central Ipswich, next to Christchurch Park.
  5. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    For non-gaming any GPU will do, for multi-screen gaming you are right, you will need a 2nd HD5770
    dunx
    P.S. I had four cards (2 x HD5870 + 2 x GTX 460 ) in my BOINC rig.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Is it not like my 5870, as I can run 3 screens off it when I'm not gaming, 1 DVI, 1 HDMI and 1 DP...
  7. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    The 5770 supports 3 monitors in eyefinity with just one card
    Sent from my HTC Sensation using Tapatalk 2
  8. Guest-16
    Guest-16 Guest
    For the price of another 5770, I'd sell your current 5770 and buy a newer, single card that does 3 monitors. I wouldn't want to **** about with older CrossFire AND Eyefinity. It's a recipe for headaches.
