Electronics Need on/off switch
Discussion in 'Modding' started by modsquad, 12 Apr 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I want to replace my CCFL's on/off rocker switch with something that looks better (aka bulgin vandal style). Something in aluminum or stainless, rocker or push-button. I have looked a 100's of switches at Mouser Electronics and Allied Electronics, but all are the cheap plastic type I have now. HELP, point me in the right direction.
    http://server6.uploadit.org/files/jeffrey9-IMG_switch.jpg
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    If you're going for a Bulgin Vandal-Resistant swtich, you'll need to build a circuit to go between the switch and the inverter. The Bulgin switches are SPST-NO momentary switches. This is a problem since you need that switching actino to latch the inverter on/off.
    You can either get a latching relay (translates momentary change into a latching action on the outputs) or build a relatively simple circuit involving a D-type flip-flop IC and power transistor. The second circuit is exactly what you need, only on the output you'll need to put a 1k resistor connected to the base of a beefy enough NPN transistor. A 2n2222A should be sufficient for dual-inverters, but the sucker will got hot, so make sure you don't touch it when it's running.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Another 4013 flipflop circuit here uses a power mosfet as the switcher with a belt & braces debounce system.
    Voltage lost across the MOSFET will be about 100mV @ 1A, which is better than a NPN, so it won't get so warm.
    /pimp :naughty:
  4. modsquad
    27 Feb 2004
    Honesty, am not looking to make a bulgin vandal switch latching. I am looking for a nice bulgin _looking switch, simple on/off. It seems all the nice switches out there are momentary, no matter what brand. I am not having any luck finding what I am looking for. How about places to shop for switches US?? HELP>>>>>>
  5. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    For nice big alu on/off switches, check your local car tuning store. Or big hardware store's.
    Why do u guys need to buy EVERYTHING of the net? lol
    L
  6. modsquad
    27 Feb 2004
    :D
    LAZY_____
