need overclocking help plz
Discussion in 'Hardware' started by ltryan, 26 Mar 2004.
  1. ltryan
    ltryan What's a Dremel?
    23 Mar 2004
    i have a 2500 barton , chaintech apogee 7njl1 mainboard , 512 ddr400 ram i can only go as far as 2800 any one know how to push it higher plz help :waah:
  2. maki43
    maki43 I can touch my toes 1,2,3
    8 Nov 2002
    If you have pushed it as far as you can on stock voltages, bump the voltage up a bit. Max on air about 1.9v just go up in steps untill the clock speed is stable :)
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Some more info would be helpfull.
    What is your multiplier set to ?
    What is your FSB set to ?
    What CPU core voltage are you running ?
    What RAM voltage are you running ?
    What Northbridge voltage are you running ?
    What make an model of RAM do you have ?
    What RAM timmings are you running ?
    A Barton 2500 should run fine at XP3200 speed, 11x200 with a little increase in core voltage, and assuming your RAM can handle 200MHz (well DDR400 PC3200 will do)
  4. ltryan
    23 Mar 2004
    What is your multiplier set to ? set to default
    What is your FSB set to ? 166mhz
    What CPU core voltage are you running ? set to default
    What RAM voltage are you running ? set to default
    What Northbridge voltage are you running ? set to default
    What make an model of RAM do you have ? hynix ddr 400
    What RAM timmings are you running ? 8.3.3.11
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Lets assume that your Processor is multiplier locked (all newer ones are), thats not a big problem because its deafult is 11 which should give a stable result.
    This only leaves you the option to increase the FSB, which I take it you have already tried.
    You wont need to increase the RAM voltage untill you start getting above 200MHz FSB, but as you get to 175MHZ or there about, you will need to start increasing the CPU voltage.
    Just increase the FSB, if it fails to boot or crashes increase the voltage a little, keep doing this until you find its limits.
    11x200 should be very achevable.
    Your RAM timmings appear a bit strange, is the first digit (8) you CAS figure?
    If it is it should be set to 2, 2.5, or 3 .
  6. ltryan
    23 Mar 2004
    frequency =199.6 mhz
    fsb:dram =5:6
    cas#latency =3.0 clocks
    ras# to cas# delay =3 clocks
    ras#precharge =3clocks
    cycle time (tras) 8clocks
    cpu settings
    multiplier =x11.0
    fsb =166.4
    bus speed =332.7mhz
