Modding Need quick help with an LED problem.
Discussion in 'Modding' started by Shadowspawn, 1 Sep 2003.
  1. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    I have a thread in electronics, but I need this mouse pad done asap, so I am posting a quick question here...I will show the finished result here a bit later, assuming this problem is quickly answered.
    I have some blue leds. They work off of 5 volts, directly connected to a molex. At 5 volts, they are bright, and keeping your hand on them for more than a few seconds, burning. Not to the point that they melt plastic, but they will hurt your finger. They came with some resistors. Using one, the brightness drops down. Not as pretty, but not nearly as hot either.
    These leds are going into a mousepad. I want these leds to last quite awhile. Running at 5 volts, am I shortening their lifespan or is it normal for LEDs to run hot like that? Should I go ahead and put in these resistors to get a longer life?
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Running them directly off of 5v, yes, you are shorting their lifespan. The resistors are there to limit current to a safe level. For now, put the resistors in and deal with the diminished brightness. Later on, you can play with resistor values and see what works best for you. What'd be helpful is if you had a multimeter (refer to signature) to test how many ohms the resistor is and how much current the LED is getting when it is connected to said resistor. If it's around 20mA, then it's probably best not to toy with other resistors.
  3. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    yeah definately put the resistors in if you want it to last :)
  4. Shadowspawn
    1 Jul 2002
    Ive got three multimeters. Never thought to use them. :duh:
    /me runs into shop
  5. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    Always use resistors with LED's even if its only something small in value. Overdriving your LED's by 5-10mA or so wont hurt em that much, overdriving them with no resistor will. LED's have a MTBF greater than 100,000 Hours (11 Years !) so overdriving them a little wont hurt :)
  6. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Could it be that the resistors supplied with the LEDs are intended for running the LEDs from 12V and not 5? What are the resistors' values?
  7. Shadowspawn
    1 Jul 2002
    Thanks for the help guys. I tested the resistors with a multimeter and determined that they were 470 ohm. I swapped my power source over to 12v and the leds are working like a champ...bright, but not hot.
    The mousepad is complete, but for some stupid reason my web server isnt getting requests, even though I have the port forwarded to it. I'll work on it more tonight and post the pics of the completed mod.
