Right, next friday, Payday. Getting me some new hardware 2.4ghz CPU, 256DDR, all to fit my mobo i brought ages ago for £20.. anyways, since i have to take everything out, i was thinking about spraying the frame that holds the case together, do i need to sand this or anything? or can i just spray away after the obvious dust removal? also, any colour suggestions? you can see my case in the link on my sig, better pics towards the end. cheers kev.
a lot of people think differently about painting...painting a case is different from a house and different from wood...sanding is totaly up to you...if i have a metal case and want to paint it i sand the old paint away...dunno if this is really required its just what i have always done...if you choose not to sand i would imagine you use some water and soap and clean all the fingerprints away that could later on cause paint to chip or come off easy
painting depends on the surface you are painting. If the surface is a glossy smooth surface yes definatly sand it down so the new pant has something to stick to but if it's just bare metal or that speckled beige powder coating then it's not really necassary but may be worth it.
