Build Advice Need some help with headphones...
Discussion in 'Hardware' started by daisy20121, 20 Jul 2012.
  1. daisy20121
    daisy20121 What's a Dremel?
    20 Jul 2012
    Hello !
    I need a pair with super-excellent base. I could do with both headphones or earphones. I need to get 'em for 2 greens, so it could be anything below 200 pounds... Any suggestions?
    I've been looking at Beats Headphones as they are cool and not so expensive.
    the only thing i dont like about them is they havent got a mic to use to on iPhones for talking through them on calls. can anyone recommend me any that are similar to these. price range around £150
    Thanks
  2. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    I would go with Sennheisers. You can get a really nice pair with a mic.
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Ew Beats. Those things are utterly blown away by things like Sennheiser HD 515, if you've really got the high-end money; Something like the Sennheiser HD595 are also an option.
    However; if you're looking for just a set of headphones for pointless amounts of bass while on an iPhone (Which doesn't have the most amazing output in the world for audio.), just grab a set of Skullcandy Skullcrushers. They've got enough bass to blow a few doors out, despite being a bit one-tone, and they're available for 40-50 quid last time I checked.
  4. Parge
    16 Jul 2010
    Beats do have excellent Bass, but are totally lacking in many other areas, one of which is comfort. If headphones aren't comfortable, you won't wear them, end of story.
    Go into Best Buy and try a few pairs on.
  5. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Sony XB700 for bass my friend
    Or if you have the cash, XB1000
    Also, some versions of the Beyerdynamic DT770 are extremely bassy.
    Sennheiser headphones aren't known for their bassiness, just thought I'd point that out.
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Skullcandy Aviators look nice and sound great as well, and have a mic.
    Another model to consider is the Sony ZX701ip which come with a mic.
    If you're looking at Beats, look for the Studio or Pro models, the rest are quite poor.
  7. ResCyn
    ResCyn What's a Dremel?
    23 May 2011
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
