Modding Need some help with UV questions
Discussion in 'Modding' started by therider, 12 Mar 2002.
  1. therider
    therider What's a Dremel?
    11 Mar 2002
    I'm thinking of a UV tube mod. Having never used one. Some questions on what outcome I can expect.
    I've seen UV nail varnish etc being used to highligh edges, but will any white surface glow? like a white t-shirt does in clubs?
    Them UV pens used to mark cash and valuables, anyone used one to highligh edges? any good results?
    Finally how long does a)The bulb itself & b)The UV painted surfaces last?
    cheers in advance,
    ride
  2. ToM
    ToM mmmm, blud
    14 Aug 2001
    any uv pen etc will work, but unfotunatly, white doesnt reflect uv, its the phosphers in your washing powder that make your shirts glow in night clubs, not the shirt itself!!!
  3. therider
    11 Mar 2002
    my any my clean clothes, tut!
    Is there enought phospher in wasing powder to make home made UV paint/paste? Probably a bad idea. I Picture bubbles comming out the pc case :D
    But ppl eyes and teeth glow under the uv?
    ride
  4. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    is UV the same as blacklight or are they two different kinds of light? if they are different, then whats the difference between them?
  5. therider
    11 Mar 2002
    well i'm using ther terms UV and blacklight as the same.
  6. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I bought some of that Conformal Spray that Macroman is always talking bout, got it at a local electronics store. I think he said Maplins carries it. Its for spraying pcb's. Make sure it says its UV reactive on the can. The stuff i got was like $15 and it glows blow under a black light. If you look at his guide on painting fans, you will see its effect at the bottom. I did some spiral wrap with foir a test and it glows really nicely.
  7. therider
    11 Mar 2002
    Yea, I want to white spiral wrap all my cables, and make em glow :D
    I think i'm gonna put in a blacklight and a blue neon using them alternatly of course!
  8. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  9. korben
    korben What's a Dremel?
    20 Feb 2002
    Or you could use UV reflective tape, as seen in this article @
    moddin.net
