Memory Need Some Memory Help
Discussion in 'Hardware' started by Advent10, 16 Sep 2010.
  1. Advent10
    Advent10 What's a Dremel?
    13 Sep 2010
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    On the (probably) correct assumption that it is an X58 motherboard, what CPU cooler are you going to use?
    The reason being is that, depending on the board, some coolers may not fit with taller RAM installed e.g. the Ripjaws or Dominators.
  3. Advent10
    13 Sep 2010
  4. bulldogjeff
    2 Mar 2010
    if your using the titan fenrir it'll cover the first slot on some asus boards, my P6TD deluxe being a prime example, so if I ever get the urge to go for 12gig it's got to come off. The Noctua NH-U12P does fit how ever, so something to think about there.
