Hi all, A close friend of mine is planning a case mod and is after some nvidia green paint similair to below So far he has thought of: Platikote Fluorescent greed and ford signal green from hycote. Anybody got any other suggestions based on experience? Thanks
Why can't he just take a picture of something with nVidia on it (or an actual nVidia card with green on it) to a paint shop and have enough mixed to do his case? I do this quite often - it's easier than trying to find a pre-mixed manufacturer colour to match.
What you getting sprayed? There's a powder coating place called BettaBlast behind Ford in Shiremoor if you know it (depending on where in Newcastle you are), I got a bike frame done there using Kawasaki Green. It looks quite similar although the bad lighting makes it look darker. If you look on their site, there's a blue Subaru with green wheels, that's a good representation of the colour.
Ive let him know cookie, said hes emailed them and is just waiting to see what they say. I think hes more likely to paint it himself though. Thanks everyone
