Modding Need some simple modding ? Here it comes!
Discussion in 'Modding' started by iSteve, 18 Jan 2002.
  1. iSteve
    iSteve What's a Dremel?
    3 Jan 2002
    Well, I was looking for some simple modding and I got an idea.
    First, I bought 6 flat, bright leds and put them into serial connection, giving it 800 ohm's (using trimer). Those 6 leds are going to be connected on 12 volts from PSU. (A big thanks to #bit channel, especially IS2)
    I bought an 500 ohm potenciometer, and an knob. Drilled an hole into 5,25" ... blinder ? (like CD-ROM but flat), fixed there the potenciometer. I put leds on the longer side of it, while potenciometer about 1cm from right side...
    Not yet sure, what I will use the potenciometer for, but I think it will be a fine control of volume :]
    - iSteve
