i have 33mb left on my hd and i aint gonna delete or defragment, etc... cos i need it all. Basically i need a hd that has 40GB or more UIDE or better since UIDE is the best apart from scsi RIGHT? AND WELL PLEASE REPLY THANKS
You mean udma ide, most ppl now agree to stay away from ibm and get either a western digital or maxtor. Also depends on your mobo if it can do udma 33/66/100/133 but if you get a udma133 hard drive it will run on udma 33/66/100 but slower than a 133. If you want speed get a 7,200 rpm model over a 5,400 rpm model. Try dabs.com i've never had problems with them or try your local computer fair.
seagates are very well known for reliability, and speed....the wd special editions are known for getting speeds of up to scsi drive specs.... either one will do you well....if you had extra money scsi would be better as its a lot faster....
get the western digtal special edition drive as it is faster than some scsi drives and you can get it from www.komplett.co.uk
O FOUND IT THANKS! I HEARD A RUMOUR FROM A FRIEND THAT IF U DONT USE ALL UR HARDDRIVE THEN AFTER A WHILE THE PART U DIDNT USE GETS DAMAGED/GOES HAYWIRE/STOPS RESPONDING! IS THIS TRUE!!?? THANKS AGAIN AND IM BUYING THE: Western Digital Caviar 80GB IDE 7200RPM Special Edition 8MB cache WD800JB FOR £101.34 THANKS AGAIN
tis is not true and in the words of a wise man a load of bull****e....correct me if im wrong but it does sound quite absurd...
THANKS U GUYS HAVE BEEN A GREAT HELP AND RECOMMEND THIS SITE TO EVERYONE (U CAN QUOTE THAT) IS THIS SITE AMERICAN OR ENGLISH (NO MORE QUESSIES PROMISE!)
ask all you want...loads of people here love to help others out... tis is an uk site, with an international reputation, so dont worry if youre from the states, uk or anywhere else in the world....
