I need two SMD inductors to fix a netgear router that my friend was tryign to modify. I've found a replacement but minumum order is 10 units and I only need two. Anyone have suggestions for getting a pair for less than £5.28 inc VAT? This is what I was looking at: http://uk.rs-online.com/web/p/products/7255250/ P.S. I have an RS branch very close to me.
http://uk.farnell.com/murata/lqh43cn680k03l/inductor-1812-case-68%C2%B5h-10/dp/1515476 ???? You will have to pay postage, RS may be the cheaper option if you are planning to pick up.
have you tryied ebay? http://www.ebay.com/sch/bestshop2008hk/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686 This seller specialize in SMD and LED but you might not be able to get less then 10 with this seller but determining specific color and size the price is fair to amazing. One good thing this seller speciallize in acouple unique SMD including hotpink and UV from size 0603 which is needle pin small to 5050 which is PLCC2 size. Oh my mistake I thought you were refering to surface mount diode as in light emiting diode My mistake
