Hi everyone I need dvd xcopy or a program that will do the same exact thing. I am looking to burn dvd movies. I look forward to your responses
First Result? Seriously....google. Are you looking to burn dvds from video files you have on your computer or make a copy of an existing dvd? Your post was a little ambiguous.
What am I looking for I am looking to burn full length dvd movies and burn regular files i.e (audio, data, etc. I am looking for the best and most user friendly software. Any more info needed just let me know. Thanks
What, like one that does everything? Nero will do it all, but it wont backup your movies. Just use dvdshrink to backup the disk to fit on a single DVDR and then whack the files in Nero.
personally i use dvdXcopy platinum for backing up the kid's movies ... and nero 6.something for everything else. no problems.
hi I guess I didn't make my self clear enough. I need to get my hands on a copy of dvd xcopy for free if possible, or a software that will do EXACTLY the same thing, nothing almost like but the same thing. Thanks
Hi, Maybe you can try the software named http://www.winavi.com/video-converter.htm . In fact, it is is a complete solution for video file converting and burning.
