Windows need to find software !!!!!! camera
Discussion in 'Software' started by lord nicon21, 25 Sep 2004.
  1. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    hi is there some software that i can use
    to get video of my dv camera by USB 2
    the camera has a usb cable with it or do i need to use firewire?
    any help would be cool
  2. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    Model camera would help.
    :D
  3. lord nicon21
    29 Sep 2003
    jvc gr-dx97ek
  4. Tech-Daddy
    8 Oct 2003
    Going to do a bit of research. I'll type back in a bit what I find.
  5. lord nicon21
    29 Sep 2003
    thank you
  6. Tech-Daddy
    8 Oct 2003
    There appears to be drivers needing to be loaded to get the USB interface up and running properly.
    http://www.jvc.co.uk/files/instruction_manual/lyt1247-001a.pdf
    You can stream video to your PC via the USB cord, or install it and access the device like a USB Mass storage device.
    Do you have the install CD for the unit?
  7. lord nicon21
    29 Sep 2003
    no i don't :waah:
  8. lord nicon21
    29 Sep 2003
    i can't find the drives :wallbash: jvc website is't very good
  9. Tech-Daddy
    8 Oct 2003
    You are not kidding!
    That JVC site sux big time!
    Americas, UK, Europe, and Japan.... the only hit I get on that model is in Europe, and it is only documentation. :duh:
    I'll keep looking!
    Called JVC Customer support?
  10. lord nicon21
    29 Sep 2003
    Called JVC Customer support nop don't really want to :wallbash:
  11. Herbicide
    Herbicide Lurktacular
    27 May 2004
    driverguide may help.
    The generic login is 'driver' (or is it 'drivers'), 'all'
    hope this helps.
    - H.
