Disaster Need to keep a lid on things
Discussion in 'Modding' started by Loom, 29 Apr 2009.
  1. Loom
    Loom What's a Dremel?
    10 Aug 2008
    I'm not sure if this belongs to the Technical Support forum, but here goes:
    Any ideas on how to close my lunchbox? I've thought about a solution involving a bodyslam from the top rope but I prefer not eating my sandwiches with a spatula.
    Edit: OK, so it's a sandwich and not a sandwitch :hehe:
    Red 5, notatoad and Guest-16 like this.
  2. stuartwood89
    20 Aug 2008
  3. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    mvagusta likes this.
  4. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Posting in an epic thread, toasting in an epic bread.
  5. jhanlon303
    7 Sep 2006
    This is what you really need!
    An original Macintosh Classic carry bag. This will hold the samwhiches and a couple beverages too. Of course you would lose all your accumulate B-T cool.
    john
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Put less stuff in your sandwhich.
  7. Atheistmunk
    Atheistmunk planing future mod
    27 Feb 2009
    to fit more/larger sandwiches eat one or more then fit the other to fill the hole where the old sandwich was
    that should work:D
  8. capnPedro
    11 Apr 2007
  9. SiG
    SiG What's a Dremel?
    3 Dec 2007
    If my eyes are correct, then you have 4 sandwiches, yes?
    What about having the sandwiches on their sides? I'll demonstrate with crude ASCII:
    | || || || || | instead of
  10. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Definitely the right place for the thread.
    I've heard Langer has access to a multi tonne press. Might help solving the problem. :D
    Probably the best thing would be to get a larger box or use two of them so even more stuff can be stuffed in.
  11. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Ooh, you have the same toaster as me! :eek:
  12. SiG
    3 Dec 2007
    *ding* :idea:
    Problem solved! And it will stop things from falling out of the sandwiches too!
  13. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    mmmmmm lunch! Brown bread Cheesecake!!!
  14. talladega
    talladega I'm Squidward
    18 Aug 2007
    squash them a bit? they taste better when squashed a bit.
  15. capnPedro
    11 Apr 2007
    I won't believe this until Bit-Tech does an impartial review. I want benchmarks, damnit!
  16. stuartwood89
    20 Aug 2008
    It's true. I squash down my cheese sandwiches and they taste much better.
  17. talladega
    18 Aug 2007
    it's easy math. more sandwich, less air = better taste.
  18. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Add some Nuts to the Base, and holes to the Lid, simply screw your lid on. 6 bolts should do it :p
  19. Loom
    10 Aug 2008
    Thanks for all the replies.
    NOOOO!
    That's what I usually do but I need 4 sandwiches this time.
    YEAH! That will definitely score me some masculinity points!
    Problems is then it would still not fit vertically and I would need some filler on the side (which is actually not a problem at all :naughty:)
    Phew! That's a relief.
    Actually it's not mine but I use it the most.
    Oooh, I would like to have one of those but one that takes 4 sammies at a time.
    ... with the added benefit of less air = less flatulence.
    Sounds manly enough but to keep the box intact I'll rather use some large clamps
  20. kenco_uk
    28 Nov 2003
    I would substitute the sammiches for a cheesecake. Much tastier. Plus, you'll have no bother getting the lid on.
