Windows Need to restore Task Manager to it original view.
Discussion in 'Software' started by angel_dust, 15 Jan 2010.
  1. angel_dust
    angel_dust What's a Dremel?
    13 Apr 2008
    Hi all
    I need some help please.
    I've just performed a clean install of Vista x64 but every time I launch Windows Task Manager it only launches on the Processes tab. There are no tabs to change the views to CPU or application usage and so on, and there is also no tool bar at the top.
    How do I get the Task Manager back to its original view Its driving me mad trying to get it back to normal??? :confused:
  2. Lankuzo
    Lankuzo CPC Refugee
    23 Apr 2009
    double click on it
  3. angel_dust
    13 Apr 2008
    Cheers man
    That was nice and simple. Theres always a simple fix I just never noticed it :duh:
