Cases Need Your Advise Please?
Discussion in 'Hardware' started by vegettoxp, 4 Oct 2009.
  1. vegettoxp
    vegettoxp What's a Dremel?
    26 Jul 2006
    Hello there Guys, I am back with my final decision for my current Rig. Some of you make have followed my Building a New Rig Thread and thank you for all your help. I have made up my mind and I am gona be updating the following Items with my current Rig. I just need your advise on if it is a good or bad choice. Again Thank you for all your help guys.
    Current Case - Lian Li PC-7FW (Black). Planning to update my current case for cooling reason and future proof case and my choices are Following CM Cosmos 1000 or CM Cosmos S, Which one would you guys recommend me getting?
    Current Headsink - Thermalright Ultra 120 w/120mm Fan. Planning to update with with the following cooler -Prolimatech Megashadow w/120mm Fan. Good Choice or Bad?
    Current Graphic Card - nvidia 8800GT. Planing to go with either ATI 5850 or 5870. But I am also keep the door open for nvidia GT300 Lineup. Your Thoughts?
    Power Supply Not Sure (Current Corsair HX620W) Keep or New One?
    Also on a Side-Note, Is the Corsair Dominator GT Memory Airflow Fan Universal? Do they fit any module setup?
    Again Thank you for all your help guys and help me with my Christmas Gift List.:thumb::rock:
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I like the thermalright, I mean unless you don't like the looks or something.. the corsair ram cooler will be fine, it clips over the ram clips on the mb
  3. vegettoxp
    26 Jul 2006
    I have Thermalright right now and there is no problme. I was thinking that I might do little bit OC on the processor. But I also know that if I get the CM Cosmos S that I will need a small heatsink because the side fan is gon aget in the way.
    Thanks for the comment on Corsair ram cooler, I really like those.
  4. vegettoxp
    26 Jul 2006
    I guess No Comments?
  5. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    Dude that Thermalright is arguably the best air cooler around in terms of performance.
  6. bagman
    bagman Minimodder
    18 Apr 2009
    if i was you i would keep everything you have got and overclock everything. and wait for the new GT300 series to come out and windows 7
  7. vegettoxp
    26 Jul 2006
    Well regarding the case, I have bought the Cooler Master HAF 922, Your Thoughts?
  8. thehippoz
    19 Dec 2008
    probably have to wait or pm bindi.. he's probably stuck his hands in all the cases :hehe:
  9. vegettoxp
    26 Jul 2006
    I did some quick research and the case looks to be pretty good. Also I watched some Youtube videos and for most of them all said good case. MB Tray not removable, I don't mind , but what really got my attention was Those 3 200mm Fans. (In front, Top and Side) now that is some serious cooling. I Plan to do some mod with the case and make it looks even better. So far I have nothing but Positive things about CM HAF 922.:thumb::rock:
