Electronics Needed: Someone to make throbber circuit
Discussion in 'Modding' started by Captain Slug, 8 Feb 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I need an adjustable dual output 12V throbber circuit made, similar to the one in this article.
    http://www.bit-tech.net/article/78
    I would like the optional continuous/throbbing switch integrated so that I can switch each output. I would prefer that this switch be done with a jumper so that if required I could easily convert it to a toggle switch later on.
    Could anyone do this or recommend someone on this forum that does make custom circuits?
  2. devenfore
    devenfore LANCandy
    8 Jul 2003
    all you need to do wire it so that the +12v either goes straight to the lights, or through the circuit. You should be able to do this very easily with a toggle stitch. GL. If you need more help, maybe I will post a modified schematic later.
    It's even kind of shown what you want to do on the link.. isnt it?
  3. c.cam108
    c.cam108 Member
    14 Feb 2004
    What is it that you are wanting?
    I think you have asked for a throbber circuit. The one in your link is what you need. You answered your own question! :confused:
    If not, can you explain.
    Thanks
    _C
  4. Captain Slug
    25 Nov 2001
    I want this
    Integrated with this as a jumper setting
    And I need someone to physically make it for me because I don't have steady enough hands to do it myself. This unit will be integrated into a single box with a CCFL inverter. The first Output will be driving the CCFL inverter, and the second output will be driving 12V LED Arrays. All as a part of this project.
    http://forums.bit-tech.net/showthread.php?t=73574
  5. Captain Slug
    25 Nov 2001
    Oh well. I guess I'll have to live without it or wait until i can do it myself.
