A/V needing help, dual speaker systems
Discussion in 'Hardware' started by seebul, 20 Dec 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    hi, im havin a house party in the new year and ovbiously that means loud music :D which i want to run off my pc, the problem is that my speakers downstairs run off usb and my speakers upstairs run off normal 3.5mm jack converted to RCA plugs. Both speaker systems are plugged in but my pc wont let me use both at the same time! windows meadia player plays through the speakers upstairs and itunes plays through the ones downstairs :waah: I ovbiously want to use only one program for both sets of speakers, does any1 know how i can do this?
  2. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    So you want to play the same music on two sets of speakers?
  3. dom_
    dom_ --->
    4 Jan 2004
    the usb ones are an external soundcard i guess from the usb.
    so unless you can find an audio program that can output to two soundcards your not gonna be in luck.
  4. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    A DJ type program might work? Worth looking into? Mix Vibes is what i use, and im pretty sure it has the right feature.
  5. Thadeez
    Thadeez What's a Dremel?
    20 Dec 2005
    Are the two sets going to be used in 1 room, or two different rooms?
    Maybe you can try to connect the jack connector with the external soundcard?
  6. seebul
    seebul Minimodder
    9 Aug 2005
    cheers guys, there is no external sound card though, the usb speakers go thorugh a subwoofer first and then to a usb plug. And there going to be in different rooms, With the same music.
  7. Thadeez
    20 Dec 2005
    Then i think you might want to check the DJ software P2D mentioned.
  8. dom_
    dom_ --->
    4 Jan 2004
    so how is the sub connected to the pc?
    you have one 3.5mm jack connected for one set and what else?
  9. Thadeez
    20 Dec 2005
    As i understand, the sub is connected to the PC using USB.
  10. seebul
    seebul Minimodder
    9 Aug 2005
    yeh thats right, and then the two speakers plug into the sub.
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    The USB 'speakers' act like another soundcard, iTunes and WMP can only play to a SINGLE soundcard.
    You will need another program that is able to output two both, most DJ programs should manage this.
  12. P2D
    26 Mar 2004
    http://www.mixvibes.com/mv6/MixVibes6demo.exe Try that, I'm not sure how you set it up for dual outputs but i read you can have dual outputs, Altho you might need the Full version which will cost. I'll go have another look around the interweb for something else now.
    Mike
  13. P2D
    26 Mar 2004
    Right, I've found a possible solution here, and i've tried it and it works. Firstly i need to know, Can you hear the speakers playing downstairs, from upstairs and visa versa. Also, Are you planning on setting up a playlist (Would be easier) or just picking odd songs throughout the night. Would it be good to be able to play two different songs- one up one down? Because that would be do-able. As soon as you answer this i'll write you up a quick How-To.
  14. seebul
    seebul Minimodder
    9 Aug 2005
    thanks alot p2d, yeh i can hear the speakers from downstairs/upstairs and yes i will me making a playlist, but wont really need to play different things on each set of speakers, although it would be cool to know how!
    cheers mate :thumb:
    i can add u on msn, if its easy for you to tell me on there.
  15. P2D
    26 Mar 2004
    Ok firsty i must praise my dual screens for making this mucho-easy.
    Anyways for this i've looked into Winamp seeing as i use it and naturally assumed you do. Right, open up a copy of Winamp. Click "Options" and click "preferences", A box should appear, Click on "General Preferences" and select "Allow Multiple Instances" then click Close.
    Now, open another instance of Winamp while leaving the first open. Assuming you've already set up the first winamp to use soundcard (1) (as i'll call it) Leave that alone. Now with the new Instance you've opened go into "Options>Preferences>plug-ins>Output" Double click "Direct Sound Output" to which another box should appear. Under the "Device" tab, Click the drop-down menu and select Soundcard (2) as your output Device. Click "Apply>ok" and the box will dissapear. Now click "Close" On the Winamp Preferences box. With the new Instance of Winamp. May i suggest chaging the colour scheme so its easier to know which is which. Open a music file and Play, It should play through The Speakers its connected to, Now pause it and with the other Instance, Open and play a music file to test its outputting to the different soundcards.
    Now simply create a playlist as you normally would and load it into both instances of Winamp, Now set both Instances to "play". Unfortunatly one will be very slightly ahead of the other, Altho the faster you click "play" on the 2nd instance the shorter the gap (if you understand). To play two different songs at once is simple, Just open a song on instance one (EG:, Red hot chili peppers) and play, Then on Instance two, play something else (EG: James Blunt)
    Hope that helps, If you have *Any* Questions at all just ask and i'll try my hardest to help you.
    Mike
    edit:
    Go for it :thumb:
  16. seebul
    seebul Minimodder
    9 Aug 2005
    thanks alot mike, i actually dont use winamp so im gonna go off and download a copy of it now, thank you for the help! :clap: :rock: :thumb:
  17. P2D
    26 Mar 2004
  18. P2D
    26 Mar 2004
    So did it work? Let me know.
    Mike
  19. seebul
    seebul Minimodder
    9 Aug 2005
    no it didn't work for some reason not really sure why.
    i tried adding u on msn but the person who was on it sed you have a different address??
  20. P2D
    26 Mar 2004
    Person who was on it? Weird. Its Prepare2die__@Hotmail.com Just copy that EXACTLY, with the underscores. I'll see if i cant find out why it wont work.
