Electronics Neon String Connectors
Discussion in 'Modding' started by Lazy, 27 Apr 2002.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    i was going to connect some 3.5mm jack plugs to my neon string but then friends dad who is very good at electronics said that there might be problems with insulation and that electricity could jump between the two connectors that you use to wire up the 3.5mm jack plugs and cause a short circuit.
    I am not a "electronics" person and was wondering if anybody could explain this a little better and........
    Would this only happen if you attached speaker wire to the neon string then put it into the 3.5mm jack instead of putting the neon string wires straight into the 3.5mm plug.
    If anyone can a)understand this and b)give me an answerthen i will be very very impressed :D
  2. macroman
    macroman The One
    3 Sep 2001
    He is probably refering to the fact that neon string runs off several hundred volts and mini jack plugs are only designed for a few tens of volts at the most.
    The insulation that seperates the contacts may, (good chance it won't), break down, effectively reducing the voltage to the string causing it to not work.
    Of course if you use a metal bodied plug you will also enjoy the delights of several hundred volts stimulating your nervous system ;)
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    okay thanks for the reply i will ask him if that was what he means.
  4. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    I got a few tingles from my inverter, also woke the gf up in the morning with it one day :p btw, dont let inverters run without any string as they dont like it for long hence me ordering another inverter a day later.... Phono plugs would probably be better for this as there is a big gap between the diff voltages and also you won't short the plug when plugging in, with a jack you would and thats a no no. Use some heat shrink to keep the cables apart over the soldering joints too.
  5. viridius
    viridius What's a Dremel?
    7 Apr 2002
    What's the neon string voltage? Most RCA jacks go to 150VAC.
