Modding neon string?
Discussion in 'Modding' started by Mombassaa, 27 Sep 2003.
  1. Mombassaa
    Mombassaa What's a Dremel?
    27 Sep 2003
    hey
    i am a new comer to modding. and i thought i wud start small. so neon string appealed to me.
    i was thinking maybe to my keyboard or mosue mat.
    but.... i have noticed they have a inverter on them.
    how far away is the string that glows , from the inverter? because if its only 10cm , it will be viewable on my desk, which wud be ugly.
    also, can you cut neon string?
    and if the inverter is a short distance from the glowing part , can you extend it?
    help wud be nice!
    cheers :thumb:
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    as far as i know-- you can cut EL string not sure about neon string.. but EL string is a lot more versatile, also it glows right from the inverter hookup, but that is extremely small....
  3. Mombassaa
    27 Sep 2003
    right ok , so i could hide the inverter in the keyboard say?
    so if i bought a length say 5 meters, and i only needed 4.75 meters, i cud just cut of the 0.25 with a knife?
  4. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    You can extend the distance between the inverter and the string using ordinary wire - I've done it :)
  5. Mombassaa
    27 Sep 2003
    ahh right cheers mate :thumb:
    ill have to do that!
