Windows Neptune's Pride II - NEW GAME STARTING
Discussion in 'Gaming' started by Cei, 15 Apr 2013.
  1. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    turns out you can also spend all but $2 before you realise you need another carrier to reach your last outlying planet :(
    that said, i've only got one planet still to reach that i might be able to see others from, i have no idea where i am in relation to you guys so i may pick the send all your ships in one direction option. If I turn up on your doorstep unannounced i apologise.
    fuus likes this.
  2. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    Hm, sadly tablet mode ain't all it's cracked up to be. Glitches on the carrier screen.
  3. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    Odd, mine works fine through Chrome on the Ipad
  4. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    Banana Farm is an awesome planet name :D
  5. Blazza181
    19 Apr 2011
    It works quite well, but sometimes it just stops, entirely, on Nexus 7.
  6. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    How on earth do you get a decent amount of money coming in, only got £150 this cycle -.-
    fuus likes this.
  7. fuus
    4 Dec 2010
    I got the same!
  8. [ZiiP] NaloaC
    [ZiiP] NaloaC Well-Known Member
    9 May 2008
    Expand and bump up your economy on all your planets. Save cash for a cycle or two if you have to. Each level of economy gives you $10, so a planet with level 4 economy will produce $40 a cycle. You can increase this with banking, but that does not affect the base income from planets, it's just an additional $50 per level of banking research you have in total.
  9. adrock
    5 Dec 2006
    I can't see any more planets. guess i have to research scanning before i can expand?
  10. Blazza181
    19 Apr 2011
    190 for me.
    It's 10 per level, and 50 per banking level. So, it's better to spread it out over planets to get the same effect, isn't it, Fuus? -_-
  11. mrMonkeyChunks
    4 Mar 2012
    if anyone wants I can jump the game forward by 1 and 6 hour increments.
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    Early economy is how you win NP. Invest in that, and later on you'll have stacks of cash to pay for research (which is expensive), ramping up your industry to insane levels and warp gates. In the earlier game, I won probably because I maintained an economic lead the entire way through, even if I had less planets. This means that when I did go to war, I could fund huge jumps in ship production, and I also had piles of money to invest in an extensive warp gate system pretty early, so I could pull fleets from all over my planets, even those the furthest from the front line.
  13. adrock
    5 Dec 2006
    Most of my cash has gone on economy so far, but as I can't see any other stars the proud people of Yellowtopia think they're alone in the universe.
  14. adrock
    5 Dec 2006
    I can still only see the same 10 stars i could at the start, have i gone awry somewhere, or do i just really need to get a bunch of scanning/hyperspace research done?
  15. Cei
    Cei pew pew pew
    22 Mar 2008
    Yep, something you can tell from in game. You'll have two circles surrounding a selected planet, which indicate your hyperspace and scan ranges. If a planet is outside this, you get nothing.
  16. adrock
    5 Dec 2006
    ok, cool. i take it as the hyperspace ring is initially larger i'd be better researching that rather than scanning in terms of trying to see other stars and work out where i am?
  17. Cei
    Cei pew pew pew
    22 Mar 2008
    The hyperspace ring is larger simply due to the metrics of how the research levels relate to distance. Hyperspace is (off the top of my head) x+3 light years, whereas scanning is x+2. Each level of either adds 1 LY of distance.
    Personally, I'd push for hyperspace range first. You won't run in to other players in the initial expansion phases, and capturing a new planet at hyperspace tech 2-3 may bring new planets within scanning range.
  18. adrock
    5 Dec 2006
    yeah, that's my thoughts too. and it's not like i'm spreading my ships too thinly, as currently they have nowhere to go, so if i send 50-100 to the first planet i see, they can move on from there (is 50-100 excessive/not enough?).
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    50-100 is batshit for this early stage. My fleets were like, 10-15. That said, if you're constrained to a single system to advance to, then yes, go for it.
  20. adrock
    5 Dec 2006
    i figure if i send them out, depending on what they find they're not really expected to come back.
    I used a single fleet of 5 to grab the 4 stars i can see that weren't mine to start with, the rest of my ships were all really centralised 'til last night, i've moved them to the edge of my space in anticipation of seeing new stars pop up. of course odds are at least one of them is going to be sat miles away from the frontier when/if that happens.
    of course this might all just be me faffing because i currently have nowhere to go.
