Case Mod - Complete Neptune's Trident: Wallpapers
Discussion in 'Project Logs' started by Boddaker, 31 Dec 2008.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Lol! So, done in a month or so? Heck, is it too early to ask about the project after this? :D
  2. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Not at all. I already have something brewing for Nvision '09. :naughty:
  3. craigbru
    28 Feb 2008
    Just as I suspected... I'll plan on seeing you there! :rock:
  4. The boy 4rm oz
    10 Apr 2008
    A Bod mod is a great mod lol. I am loving the idea, very cool. Can't wait to see how it turns out for you.
  5. Guest-23315
    Guest-23315 Guest
    Subsricbed :thumb:
  6. headala
    headala What's a Dremel?
    9 Oct 2005
    Sub'd
  7. Boddaker
    30 Nov 2006
    After gutting the case, I started in on the side panel window design and pass-through holes. If you remember the case came with a windowed
    side panel that also had a fan hole in the upper right corner. Luckily, Moddersmart had a solid panel for the case lying around so I got that too. :)
    I penciled out the lines for the cutouts. I didn't bother to protect the surface with tape, since I will be sanding and painting later.
    Drilled some pilot holes for the jigsaw and started cutting.
    Cuts complete, but I made a tiny boo-boo. See it?
    How bout a closer look. I mistakingly drilled the pilot hole in the wrong spot. Doh!! :x
    Here is the panel on the case.
    To fix the whoops, I cut a round disc and plugged the hole, and will bondo over it later.
    On to the other side panel!
  8. The boy 4rm oz
    10 Apr 2008
    Nice cuts made for the window.
  9. jhanlon303
    7 Sep 2006
    Very nice layout and cuts for the windows!
    I'm also glad you showed the 'OOPS' shot. Makes me feel better knowing I'm not the only one who occasionally makes mistakes. I thought I was a dead loss at layout.
    john
  10. renba
    renba hooch is crazy
    2 Oct 2008
    You know how to use a jigsaw:thumb:
    Nice layout
  11. Guest-23315
    Guest-23315 Guest
    ooh! Nice window! Bob, if you want some inspiration, Franklin did an amazing V2000 Mod a few years back, called AlumaxX
    :clap:
  12. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Nice build. Great job on cutting those holes.
  13. TiTON
    TiTON IRONMODS
    23 Mar 2004
    Hey Bod.. looking good. Mod On :)
    - Ton
  14. spenc259
    spenc259 in the build stage!!!
    23 Oct 2008
    this should b gd...
    looking forward to it...
  15. Boddaker
    30 Nov 2006
    @ TiTON: Thanks man! :)
    Some progress today!
    To cut the other side panel, I used the first one as a guide. After cleaning up the cuts with a file, I layed the two panels
    together and drew out the three holes.
    Holes cut (I got the pilot holes right this time! :D )
    Then I removed the front post.
    Instead of just working with the existing floor, I opted to make a whole new one out of the old windowed side panel.
    This provides me with a clean slate so I can make my access holes wherever I need them. Using the old one as a template,
    I marked out the side panel. Had just enough material in the middle. :thumb:
    Cut, complete with mounting tabs and notches on the ends for the side panels.
    Test fit. Gotta make a few adjustments...
    Now it fits! I won't rivet it in just yet. Gotta first make all the holes I need for cabling, tubing, etc..., and paint.
    Next up will be the back panel, psu mount, and bottom radiator mounting brackets.
    :dremel:
  16. Guest-23315
    Guest-23315 Guest
    oooh exciting!!! I love that side panel!
  17. jhanlon303
    7 Sep 2006
    Me too! and the wrap around window corner is way new to me. Never seen another one.
    Very nice Bod.
    john
  18. The boy 4rm oz
    10 Apr 2008
    Coming together very nicely mate. The new divider looks very good. At least you can make the pass through holes where you want now.
  19. at0y_co
    at0y_co What's a Dremel?
    4 Jan 2009
    subscbd... ;)
  20. Colossous
    Colossous Minimodder
    28 May 2007
    Looking way cool there duder - you have an eye for the unusual approach :thumb:
