Linux nero vision alternative for ubuntu
Discussion in 'Software' started by keef247, 25 Jun 2007.
  1. keef247
    keef247 Minimodder
    11 Aug 2006
    i've tried devede and manDVD and both screw up the audio into scratchy sounds on my dvd players/ps2/xbox etc... is this a codec problem or a lack of support for a codec in the actual programs?
    I'm personally not sure either way but is there an alternative program for ubuntu 7.0.4 that will take any audio/video formats that i throw at it and convert them into dvd?
    hope I've made myself clear enough this time sorry if not:$
  2. Glider
    Glider /dev/null
    2 Aug 2005
    maybe K3b?
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I hear that the problem with audio on DeVeDe is due to a slightly b0rked version of Mplayer & MenCoder.
    If you read this thread on the Ubuntu forum, you'll see a link to a "fixed" version of Mplayer near the bottom of page 4.
    As an alternative option, I've had good results with Tovid for simple discs.
    I'm currently experimenting with QDVDAuthor for a more complicated multi-menu project.
    With Tovid, don't try to burn the finished disc. Instead, create an ISO image, and burn that with K3B. :thumb:
  4. keef247
    keef247 Minimodder
    11 Aug 2006
    cheers IanW yeah I saw the fix for it and I will try that later.but now I'm going to check out Tovid. I tried QDVDAuthor once and it annoyed the hell outta me.will give it another shot.
    as for iso's yeah I prefer that incase I require more than one copy then I don't need to clone my dvd projects burnt discs over and over(Y)
    cheers mate
