Windows Net Framework
Discussion in 'Tech Support' started by gart, 24 Oct 2009.
  1. gart
    gart What's a Dremel?
    15 Mar 2009
    Hello,
    Apologies for the potentially daft question....
    I have installed windows 7 with no problems, however for my graphic card ATI Radeon 4800 is it correct that i install the net framework 3.5 first and then the driver? if so is there a particular framework for windows 7?
    Thanks
  2. Akava
    Akava Lurking...
    28 Jul 2007
    The .Net framework is the same across all the variation of the Window OS; think of it as Direct X for applications.
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Windows 7 should come with .NET Framework 3.5 already installed.
    The driver itself doesn't need the framework IIRC, only Catalyst Control Centre.
    Not quite.
    It's a set of runtimes required for apps written in C#, not needed for all apps.
  4. Akava
    Akava Lurking...
    28 Jul 2007
    Not just C#, Direct X isn't required for all games...
    I was trying to make a simple comparison; how ever you are correct that Windows 7 should come with the most up to date .Net Framework which is of course 3.5.
